UAD-2/Apollo 附赠插件套装说明与常见问题解答
所有新注册的 UAD-2 / Apollo 产品均免费附带 UAD 插件套装。这些 UAD 插件套装开箱即用,无需额外购买,非常适合新用户。
UAD-2 PCIe SOLO/DUO、UAD-2 Satellite FireWire DUO
Analog Classics 插件套装:
UA 610-B
UA 1176LN Legacy
UA 1176SE Legacy
Pultec EQP-1A Legacy
Pultec-Pro Legacy
Teletronix LA-2A Legacy
Precision Channel Strip (Precision Mix Rack Collection)
Precision Reflection Engine (Precision Mix Rack Collection)
Precision Delay Mod (Precision Mix Rack Collection)
Precision Delay Mod L (Precision Mix Rack Collection)
RealVerb Pro
UAD-2 PCIe QUAD/OCTO、UAD-2 Satellite FireWire QUAD、UAD-2 Satellite USB QUAD/OCTO、UAD-2 Satellite Thunderbolt QUAD/OCTO
UA 610-B
Fairchild 670 Legacy
Precision Enhancer Hz
UA 1176LN Legacy
UA 1176SE Legacy
Pultec-Pro Legacy
RealVerb Pro
Arrow、Apollo Solo、Apollo Solo USB、Apollo Twin Thunderbolt SOLO/DUO、Apollo Twin USB、Apollo Twin MkII、Apollo Twin X、Apollo Twin X USB
Realtime Analog Classics 插件套装:
UA 610-B
UA 1176LN Legacy
UA 1176SE Legacy
Ampeg SVT-VR Classic
Marshall Plexi Classic
Precision Channel Strip(Precision Mix Rack Collection)
Precision Reflection Engine(Precision Mix Rack Collection)
Precision Delay Mod(Precision Mix Rack Collection)
Precision Delay Mod L( Precision Mix Rack Collection)
Pultec-Pro Legacy
Raw Distortion
RealVerb Pro
Apollo FireWire DUO/QUAD、Apollo 8 DUO/QUAD、Apollo x4、Apollo x6、Apollo x8、Apollo 8p、Apollo x8p、Apollo 16、Apollo 16 mkII、Apollo x16
Realtime Analog Classics Plus 插件套装:
UA 610-B
UA 1176LN Legacy
UA 1176SE Legacy
Pultec-Pro Legacy
Raw Distortion
RealVerb Pro
Apollo Heritage Edition 音频接口
Heritage Edition 即为人们常说的 HE 版本,HE 版本音频接口与非 HE 版本的音频接口从硬件上说并无区别,但 HE 版本除去 Apollo 本身附赠 Realtime Analog Classics 或 Realtime Analog Classics Plus 插件套装外,还将免费得到屡获殊荣的 Heritage Edition 精选插件套装。
Apollo Solo HE、Apollo Solo USB HE、Apollo Twin MkII DUO HE、Apollo Twin USB HE、Apollo Twin X DUO HE、Apollo Twin X QUAD HE
Apollo Heritage Edition 插件套装(价值1345美元):
UA 1176 Classic Limiter Collection
Teletronix® LA-2A Classic Leveler Collection
Pultec® Passive EQ Collection
UA 610 Tube Preamp & EQ Collection
UA Pure Plate Reverb
Apollo x4 HE、Apollo x6 HE、Apollo x8 HE、Apollo x8p HE、Apollo x16 HE
Apollo Heritage Edition 插件套装(价值2490美元):
Fairchild® Tube Limiter Collection
Teletronix LA-3A Audio Leveler
Helios® Type 69 Preamp & EQ Collection
V76 Preamplifier
UA Oxide Tape Recorder
注:后缀带 Collection 的是多个插件的合集,并非单个插件。
UAD 插件套装常见问题解答
问
我购买第二台 UAD-2 设备,但我已经拥有附赠的插件套装。我可以从我已经拥有的附赠插件套装中获得积分吗?
答
不可以。每个 UAD-2 设备都免费包含一套插件,我们无法将这些插件替换为其他选择。
问
我的计算机使用较旧的操作系统,因此我运行的是较旧版本的 UAD 软件。我没有看到我的 DAW 中出现一些 Analog Classics 插件。我该如何使用这些插件?
答
这些插件套装中包含的一些插件,例如 UA 610-B、Raw Distortion 和 Precision Mix Rack Collection 插件已在 UAD 驱动的更高版本中发布。如果由于计算机操作系统的原因,您运行的是较旧的 UAD 软件版本,则在不升级的情况下可能无法使用其中某些插件。不过,插件授权仍将保存在您的帐户中,因此,如果您选择更新操作系统和 UAD 驱动,此时您将可以正常使用这些插件。
问
我在我的帐户中看到了 Precision Mix Rack Collection 的授权,但在我的 DAW 中却没有看到该插件。如何使用 Precision Mix Rack Collection?
答
Precision Mix Rack Collection 实际上由四个独立的插件组成:Precision Channel Strip、Precision Reflection Engine、Precision Delay Mod 和 Precision Delay Mod L。
Heritage Edition 部分
问
我已经拥有促销活动中包含的部分或全部 UAD 插件。 我可以获得不同的 UAD 插件吗?
答
是的!如果您已经拥有 Heritage Edition 插件套装中包含的一款或多款 UAD 插件,您可以在硬件注册时从以下列表中选择相应数量的备用UAD插件:
Brigade Chorus Pedal Plug-In
Cambridge EQ Plug-In
Cooper® Time Cube MkII Delay Plug-In
DreamVerb Room Modeler Plug-In
EP-34 Tape Echo Plug-In
Fairchild® Tube Limiter Plug-In Collection
Galaxy Tape Echo Plug-In
Helios Type 69 Preamp & EQ Collection
Helios™ Type 69 EQ Plug-In
Oxide Tape Recorder Plug-In
Precision Buss Compressor Plug-In
Precision De-Esser Plug-In
Precision Enhancer Hz Plug-In
Precision Enhancer kHz Plug-In
Precision EQ Plug-In
Precision Limiter Plug-In
Precision Maximizer Plug-In
Precision Multiband Plug-In
Pultec® Passive EQ Plug-In Collection
Studio D Chorus Plug-In
Teletronix® LA-2A Leveler Collection
Teletronix® LA-3A Classic Audio Leveler Plug-In
V76 Preamplifier Plug-In
问
我已经拥有 Heritage Edition 插件套装中包含的部分或全部 UAD 插件,在哪里可以更换我的备用 UAD 插件?
答
选择您的备用 UAD 插件的处理方法与在我们的网站上兑换 Custom Bundle (插件自选套装)的方法相同。登录您的帐户,访问您的帐户页面,然后单击顶部的横幅以完成您的选择。请注意,只有当您已经拥有部分或全部最初提供的插件时,您才会看到该横幅。
注意:为避免潜在问题,请使用桌面 Web 浏览器选择备用插件。不要使用您的手机或平板电脑来选择备用插件。
问
Heritage Edition 版本的音频接口是否仍包含 Realtime Analog Classics 插件套装?
答
是的!Apollo Heritage Edition 版本音频接口附带 Realtime Analog Classics 插件套装。
注意:UA 无法将这些插件更换为其他选择。
问
我最近买了一台新的 Apollo 音频接口,它不是 HE 版。我可以用其他方式获得 Heritage Edition 插件套装吗?
答
抱歉,只有新的 Apollo Heritage Edition 设备才附带 Heritage Edition 插件。
*选择可靠的 UA 专业经销商是获得 Apollo Heritage Edition 插件套装的好办法。
