| 40种预置 + 用户自定义 (unique to each program)
| 6种模式 (FM, Ring Mod|环形调制, Filter|滤波, Filter FM|滤波FM, Wave Folder|波形折叠, Effect|音效) |
| 23种 (Sine, Sine 12bit, Sine 8bit, Triangle, Saw, Saw HD, Square, Square HD, Additive Saw3, Additive Sqr3, Additive Tri3, Additive 12345, Additive 1+2, Additive 1+3, Additive 1+4, Additive 1+5, Additive 1+6, Additive 1+7, Additive 1+8, Noise S/H, Noise White, Noise Pink, Noise Blue) |
| 11种 (LPF 12, LPF 24, LPF MS-20, LPF POLY6, HPF 12, HPF 24, HPF MS-20, BPF 6, BPF 12, BRF 6, BRF 12) |
| 23种波形 (Triangle, Saw Down, Saw Up, Square, Sine, Sample&Hold, Guitar, Exp.Triangle, Exp.Saw Down, Exp.Saw Up, Step4 Triangle, Step6 Triangle, Step4 Saw Down, Step6 Saw Down, StepRnd:Time, Triangle+, Saw Down +, Saw Up +, Square +) |
| 30种 (Chorus, Unison Ensemble, Phaser, Phaser (BPM) , Auto Pan, Auto Pan (BPM), Flanger, Flanger (BPM) , Rotary Speaker, Auto Wah, Exciter, Enhancer, LFO Filter, 3-Band EQ, Distortion, Guitar Amp, Decimator, Grain Shifter, Master Limiter, Compressor, Delay, Delay (BPM) , Autopan Dly, Autopan Dly (BPM), Tape Echo, Tape Echo (BPM) , Early Reflection, Reverb, Shimmer Reverb, Spring Reverb) |
| 多复音步进式音序器 (16个步进,每个步进支持6复音)
| 7种琶音型 (MANUAL, UP, DOWN, ALT1, ALT2, RANDOM, TRIGGER) |
| 调制轮、弯音轮、6个RATIO OP旋钮、6个LEVEL OP推杆、A-F数值控制旋钮 |
| 左/单声道 (L/MONO) 和右声道 (R) 平衡音频输出口: 6.3mm TRSMIDI输入/输出 (MIDI IN/OUT): 标准5针 |
| DS-1H延音踏板、PS-1开关踏板、PS-3开关踏板 |
